Instalation of ignighter for Amana Range
I have ordered the ignighter and located it in the oven. I need to know how to replace it before it gets here. Help Please. Amana Oven ingnighter ARG7300WW P1141296NWW
Thanks:confused:
Hi.
It’s not clear which one igniter you are replacing - bake or broil?
But in both cases you need to use the old brackets.
Remove the old igniter out and VERY carefully insert the new one in. The gray coil is very fragile.
For the top broiler remove the broiler out and use the old bracket and shield. Very important to keep the space between the igniter and the broiler burner surface the same as the old one.
Here are the breakdown diagram and Cavity replacement parts for Amana ARG7300WW RANGE- S/C S/I DDRAFT GAS | AppliancePartsPros.com
Good luck. Post the results.
Simon.
Thanks Simon, I replaced the brioler ignighter before I realized that there were two igniters. The problem I was having was with the oven, although the brioler never worked evenly and the old igniter was scortched and the wire insulation burned where they connected. Now when i turn the oven on I have no oven indicator light (the red light on the panel) it used to be red until the oven reached it’s set temp. I can see that the oven igniter is glowing red, but there seems to be no gas to ignite. I turned it on and walked away for about 10 minutes and nothing happened. I did not smell the usual gas present. We are on LP here. The stove top works, seems to be no gas to the oven. What now?:confused:
I’m about to just go buy a new range. :mad:
Hi.
Check for 120v bake side of the safety gas valve when the bake ignitor is on. If the voltage is there - unplug the range, remove one lid off and check the continuity. If it’s open - replace it.
If not - see if there any shut off valves right before the gas valve.
The indicator light may just burned out.
Here are the breakdown diagrams and Replacement parts for Amana ARG7300WW RANGE- S/C S/I DDRAFT GAS | AppliancePartsPros.com
Simon.
Thanks again Simon, I will try that asap. Need some direction from hubby for this one and he is busy. Might be a couple days before I can get back to you.
Take you time.
Simon.
