InSinkErator Disposal clogged
I boiled and softened King Crab legs and chopped the shells and fed them into my garbage disposal. The blades spin perfectly, but the water will not go down. I have tried vigariously plunging (hand plunger) many times with no results.
Any suggestions?
you need to turn off circuit breaker to disposer and remove drain pipe that comes out of it and clean out the clogg
Thanks for your advice! I was hoping to avoid removing the drain pipe. To that end I continued plunging for a very long time rather than removing the pipe. The clogg did finally move with plunging.
thanks
