Inglis oven has power, won't heat anywhere (oven or 4 elements)
Hello, my inglis 2008 oven has power, but the elements won’t get hot at all or the oven. The lights all work beside the switches, and the oven light, and the clock, and i can set the timer and heat and that’s all good. But the 4 elements won’t turn on or get hot, neither will the oven. I have tried changing the outlet in the wall that the oven plugs into, and still the same problems… Help please!
Have you actually checked the power with a meter?
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
