Last week my dryer had no heat. I diagnosed the problem as a blown thermal fuse (by bypassing the fuse, I don’t have a volt/ohm meter). I replaced the part and have run the dryer briefly since. It runs and heats but appears to be getting too hot (even in low setting). I’m worried about blowing the fuse again. Any suggestions?
You have to find out what caused it to go.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow. You did not include a model number so I am assuming that the fuse you replaced was on or near the heating coil, the hi-limit should also be close by.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut).
