Indicator light stays on
My Thermador cook top burner indicator light will not go off even though all controls are off. i did spill some liquid in the area of the controls recently. no problem before that. any suggestions?? many thanks
LMK1,
If it’s the “hot surface” indicator light, then you’d need the burner sensor or burner element.
If it’s the burner "ON’ indicator light, You’d have a shorted contact in the burner infinite switch,could have been due to the water. A model number ( if available) would have been very helpful.
Thanks,
