In door ice maker is not making ice. Plenty of water pressure available at water dispenser. Ice dispenser is operational, but no ice in ice bucket. Where do I start looking? Is there a service manual that shows how to access the ice maker in the door? Diagnostics available to help isolate the problem?
When I stated that there is plenty of water pressure at the water dispenser, I was speaking about the water dispenser in the door for dispensing water to a drinking glass. Not sure about water to the ice maker.
If the ice maker is full with ice - replace the ice maker.
If it’s empty you need to check the water inlet valve.
At the back of the frig locate water valve, switch around electrical plugs and press the water dispenser lever.
If the ice maker starts filling up, go to the next test.
I cannot see if the ice maker has ice in its trays. This ice maker is in the door and the only visible access I have is the air vent supply to it. There is no way to see what might be in the tray. Got any ideas how to get access to the icemaker without tearing the door apart first?
I checked that switch the first day. Yes, it is ‘ON’. I flipped it to OFF and ON several time to be certain it was fully set to ‘ON’ position. Still after 24 hours, there is no ice.
Next step is to check the valve. I haven’t heard any water running into the ice maker for a couple of days now but I do have water on demand to the water dispenser in the front of the refrig.
Not sure if the ice maker is going through its cycles either. Any way to determine this without tearing into the door just yet? I would like to determine if the problem is the ice maker or something else before tearing into the door.
Locate the dual water inlet valve on the back of the refrigerator. Swap the wires between the two solenoids. Use an insulated wires if the terminals have different size.
Press the water dispenser lever for a few seconds. Put your fingers into the ice maker to check if there is some water.
If there is no water, replace the water inlet valve.
If there is water, post it and we’ll proceed with the further diagnostics.
Found the problem! :eek: There were a few ice cubes jamming the ice maker, preventing it from completing its cycle. Removed and made sure there were no other cubes jamming the works and soon afterwards heard the ice tray empty into the bucket; a sound I haven’t heard in days. About 30 minutes later, when the freezer cooled back down, I heard the ice tray fill with water. Should have new ice in about an hour.
Got any idea what may have caused the cubes to jam the way it did? Is this indicative of a problem starting to surface with the ice maker or just one of those flukes that sometimes surfaces?
Unfortunately without being able to see what and how the cubes were jammed in there, it is difficult to explain. I only could reach in with my hand, through the bottom of the ice maker cavity, and feel with my fingers. The ice cubes were jammed at the top of the ice maker. Luckily I have long fingers and a not so fat hand!
Please post the results.[/quote]
I have this same problem. Ironically it was this thread that allowed me to fix my icemaker a few months ago as I had ice jamming the maker from completing its cycle.
I thought that might be the problem this time. It is not. I removed the two screws on the icemaker casing or hood and removed that after removing the Ice bucket/reservoir. This allowed me to see an empty Ice try. I manually filled the tray to see if there might be something that would happen. No Luck. Now I have a tray of frozen ice due to me filling it manually but no movement from the mechanism that would kick it out.
I saw the part about switching the plugs on the water valve. I was able to remove the white plug to the red side but cannot, for the life of me, remove the gray plug to the green side. That said I can’t perform the test you suggested.
Does the plug have a latch I cannot see?
Also. I have water to the water dispenser. Can the water in the hose to the ice maker be frozen if the water to the dispenser is not frozen? I was thinking about letting the whole freezer thaw hence the water hose would thaw as well in case it was frozen and go from there. I just did not want to try that if the fact that the water dispenser working proved the hose to the ice maker was not frozen.
[quote=Gene;698249]Locate the dual water inlet valve on the back of the refrigerator. Swap the wires between the two solenoids. Use an insulated wires if the terminals have different size.
Here is what I have done with this same exact problem.
I have read the forums here extensively and below are the results as well as other symptoms of my ice maker not making ice.
Water dispenser works.
Switched the connections on the solenoids and water is filling tray when I press on water dispenser.
Before I did the above test I followed instructions posted on another thread as far as the laser is concerned. Please note the different result when the connections were switched in step 2.
No red LED whatsoever. But , if I unplugged refrigerator and plugged back in there was a solid red LED lit. I immediately shut the door and reopened and red LED was still lit. If I shut the door and left door shut for 15 minutes when I opened the door after those 15 minutes there was NO LED lit.
With the connections on the solenoid switched and there was water to the Ice Tray via when the water dispenser was activated I noticed the LED was blinking when the Ice bucket was out. I did not note any pattern, just blinking continuous at same rate.
I put connections on solenoid back to normal positions. Plugged in refrigerator and LED acted as it is explained in step 4.
