I'm Lost
Dryer wont start. I have juice to the motor. I need to know what are the circuts that break the power flow on the motor. Door switch. start stop sitch thermal fuse timer. what am i missing
Replacement parts for Estate EED4400WQ0 29" ELECTRIC DRYER | AppliancePartsPros.com
I find the following a bit confusing “I have juice to the motor”. If you have 120 volts at 4M to 5M at the motor and is doen not run then the motor is probably toast. Disconnect it and check the windings for continuity. The motor does have an internal thermal protect.
The motor circuit is:
NEUTRAL , DOOR SWITCH COM/NO , PUSH TO START SWITCH BK/W , DRIVE MOTOR windings , THERMAL FUSE , TIMER contacts B/C , L1
EED4400.pdf (138.5 KB)
