Ignitor lites oven but shuts off
My Kenmore gas oven lites the oven burner but then it goes out a few seconds later. The process repeats itself about every minute.
Remove the oven floor and the flame spreader. Remove the Bake burner and check the lighting holes configuration in accordance with the attached picture.
If there are just four holes (as shown on the bottom picture) then the burner assembly has to be replaced.
If there are eight holes then you have to enlarge them using a one size bigger drill bit.
direct spark ignition problems.jpg (45.8 KB)
