Ignition Spark Module; Cook Range Burners
Brand: Whirlpool
Model Number: SF305PEEN 0
Main Symptom: Spark Module
Can I replace a W10110491 (4 wire connector) spark module with a W10110486 (6 wire connector) and just not use 2 of the 6 connectors ?
You would want to use the recommended spark module and not have extra terminals as this could cause unnecessary arching.
Thank you ! This had 4 wires not a 1 wire loop. With no receipts, purchased a year ago, no returns on new module, I tried it with no ill affects “yet”.
