Igniter
Kenmore Gas Range. I can hear the clicking of the igniter and smell the gas but no ignition. I’m guessing it’s the igniter but wanted a better opinion. This was interminent before. Recently did a self clean and now won’t ignite at all. Also, if it is the ignitor is it in the back or under the spreader plate inside? Thanks so much!!
In order to provide the most accurate advise I need the complete model number of the range.
I need help to install an igniter burner into a Kenmore Gas Range model number 362.75980891. Is this something I can do? Many thanks…:confused:
Hi ryant,
Which igniter are you talking about: the bake burner, the broil burner or the top burner?
