The igniter on my gas stove top will not stop sparking. I had to unplug the unit and now I have to use a match to light the burners. What could cause this?
Most likely the problem is a shorted or broken one of the ignition switches. A visual inspection can help to find a physically broken switch. If it’s shorted, it has to be tested for continuity.
- The ignition switch AP4101565
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 8341VS Surface Unit - Gas | AppliancePartsPros.com
I have the opposite problem on a Magic Chef stobve (8114P627-60). The most used burner takes a bit longer to light the gas because of a irregular/weak spark (as compared to the others). How do I fix this, how do I get into/under the top burners?
Thanks,
Macpete
Very likely the problem is a bad burner igniter.
The model number you posted is incorrect. Verify and repost it please.
The Model number is CGR3740ADW, I still dont know how to get at the burner igniter
[quote=Gene;268609]Very likely the problem is a bad burner igniter.
Gene.[/quote]
You have to turn the burner CCW and pull it up. The igniter is attached to the burner and it comes as a part of the burner.
- The burner assembly AP6008593
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF CGR3740ADW Range - S/c F/s Gas | AppliancePartsPros.com
Fantastic, I ordered the part today!
Thanks,
Mac
[quote=macpete;270496]Fantastic, I ordered the part today!
Thanks,
Maytag[/quote]
Dam, I just got the new part, installed it and the spark is still not a regular spark as the other burners Is there a electronic control box of some kind that the two wires come from, could it be defective in some way?
-Macpete
Swap the igniter wires between this and any other properly working burner close to that one. See how they work and post the results. Post the serial number of the range.
Did that and the igniter using the new wires worked correctly, this tells me that its not the igniter itself thats defective.
Serial number is 13035335UY
Thanks.
Mac
[quote=Gene;272110]Swap the igniter wires between this and any other properly working burner close to that one. See how they work and post the results. Post the serial number of the range.
Gene.[/quote]
Sounds like the problem is a bad spark module (#15 on the diagram).
- The spark module AP4010034
Gene, that is it, found the part and switched some wires around and the bad burner is now working!
will be ordering the part today.
Thanks,
Macpete
[quote=Gene;272608]Sounds like the problem is a bad spark module (#15 on the diagram).
Gene.[/quote]
