it glows for about 15 secounds but doent ignite. i double checked the gas so i know its getting gas to the valve.
from what ive been reading it sounds like the coils might be bad. i didnt check the fuses yet thou. will post tomarow after i do.
any help is much appreciated, i just dont want to get the wrong part.
thanks
Since the dryer igniter is glowing, the fuse should be ok. I’d replace the coils. 97% bad coils / 3% bad gas valve.
Dryer coils for your Whirlpool.
Breakdown diagrams for Model LG7686XPW0
Also, as long as you’re in there… Check the belt for cracks, replace if found (dryer belt). Vacuum any lint inside the dryer.
