Icemaker
I Am An Amputee With One Leg. How Hard Is It To Install This Icemaker. I Can Only See One Screw Holding The Entire Unitin. I Am Missing Something Here Thanks For Your Assistance. Patrick B.
JB,
Here’s the part number for the replacement kit,
Is this the part you have ?
AP2984633
But to answer your question,
There are usually 3 screws that attach the icemaker to the wall,
1 screw on the bottom of the assembly, near the control head, to hold the bottom to the wall.
2 screws across the top of the ice maker mold, for levelling and attaching the upper part of the mold to the wall.
( If you click on the part number I attached you’ll have a good reference to work with ).
You loosen the 2 screws across the top, remove the screw at the bottom and lift up and out to remove the assembly, then unplug the wire harness, and it’s out.
It won’t be that hard or difficult for you to do.
