Icemaker will not dispense
Brand:Kenmore Elite Bottom Freezer Refrigerator
Model Number:795.71053.010
Main Symptom:Water fills the ice tray but does not empty into dispenser when solid
What happens & when: have tried the reset button
Does the icemaker react at all if you press the test button on the bottom?
The only way we can make it dispense is to turn the ice maker off and back on and holding the ice tray upwards with a little force for the tray continues to move up and at the same time pressing the reset button until the tray continues moving upwards. Once the tray continues moving up the tray empties the ice and moves back to position it will fill up the tray with water. it takes about 60 to 90 min to freeze.
Sounds like the icemaker AEQ73110205 has lost position and will need to be replaced.
