Icemaker repair
i am trying to replace the ice box on a jenn air icemaker and i need to get the yoke off of the ice dispenser how do you remove it :confused:
Which part did you call โ€œice boxโ€?
Can you be more specific on the problem?
Here are the break down diagrams for the Jenn Air refrigerator Model JCD2389GEW
on the diagrams for the jenn-air jcd2389gew ice bin I replaced the diagram number #20 enclosure, ice. To install the new part I must remove the yoke, ice dispenser diagram # 9. How do I do this in order to fit this through the hole for the shaft
