Icemaker overflowing water
The ice maker is overflowing the ice cube mold with water.
I forced the water cycle using t&h and water valve ran for 22 seconds resulting in the overflow. Would like to know if I need a new power module or water valve?? I also tried adjusting the adjustment screw on right side of power module to no avail.
Other than that Ice maker works fine, ejects ice and so on.
i would replace the motor module. most of the times it gets stuck in the fill cycle, and overflows. tom [url=]applianceeducator.com - parts[/url]
