Icemaker over fills water
Brand:lg
Model Number:lfxc24726s /03
Main Symptom:water overfills
What happens & when:dumps ice overfills water when refilling creating ice dam in ice bin eventually stopping discharge of ice.
Parts or tests already tried: replaced both water valves, ice maker tray, checked sealing gaskets.
Does the ice maker water valve seem to hum the entre time it is filling or does it stop humming but water still goes through? This could help identify if the water pressure might need to be checked or if there is a control issue.
new valve does not hum, nor did the old one. water stops as soon as valve shuts off. everything is wet after fill. drinking water appears to be dispensing ok. i can try slowing if you think that is what it is.
It sounds like the main control is not shutting the valve off in the proper amount of time. CSP30021023 Service Power Control Board (Svc Pcb) | Genuine Lg OEM In Stock
