hi
Purchased new icemaker. Having trouble installing: 1) water hose won’t fit into new water receptacle because the receptacle is taller and 2) having problem connecting power while icemaker is in bracket. Any tips?
hi
Victor,
What is the part number of the ice maker?
thanks, but I finally got it. I 1) folded over the rubber hose to get it into the water receptacle even though it was pretty stiff, and 2) removed the screws to the base, which allowed me to slide it over enough to attach the electrical connector.
I’m glad you were able to fix it. Good job!
