Ice Won't stop dispensing
I am having problems with Ice continuously dispensing. I have taken apart the front panels and cleaned everything but still have the problem. I notice the auger is continually spinning when ever the door switch is closed. I have seen some suggestions of a couple of controller boards being the possible problem, but didn’t find the ones for my model. Any suggestions or help would be greatly appreciated.
Thanks!
Actually I found that the Auger goes intermittently. Would this be the micro switch or possibly one of the control boards. Again, any help would be greatly appreciated.
No one has anything to offer?
[quote=ChrisWurt;916575]I am having problems with Ice continuously dispensing. I have taken apart the front panels and cleaned everything but still have the problem. I notice the auger is continually spinning when ever the door switch is closed. I have seen some suggestions of a couple of controller boards being the possible problem, but didn’t find the ones for my model. Any suggestions or help would be greatly appreciated.
Thanks![/quote]
I have a Monogram GE fridge. Ice maker auger is starting/stopping randomly. I have done some research and it seems is the motherboard. Unlucky nobody replied to you with comments. Could you tell me if you fixed the issue? Thanks
