Ice Tray for Samsung Ice Maker
The ice tray for the ice maker (NTGT001TA1) in our Samsung RB195BSSB refrigerator is cracked/broken and fell out. Can just the ice tray be replaced and, if so, can you provide the order information? Thank you.
Samsung part #DA63-02284B if you’re just talking about the part that fill up with water that freezes and makes cubes…if your talking about the the tray assembly that holds all the ice cubes after they’re made it’s samsung part #DA97-02790A…Also Samsung’s are infamous for various issues with there refridgerators so you may be waiting for a long time for the parts i’ve seen 2-3+ months then when the part get’s there they shipped you the wrong part alot of times. Also provide the serial number on the actual part itself that you need if there is any number on it when dealing with samsung products they are infamous for changing parts in the middle of the year on models and putting cheaper made aftermarket parts that don’t fit right or are not the original model parts. Good luck
