Ice not dispensing
Brand: Whirlpool
Model Number:WRS555SIHZ06
Main Symptom: Ice not dispensing
What happens & when: water from fill tube leaking into ice box and freezing ice cubes together as well as agitator
Check and ensure the water pressure is correct, then check for a water inlet issue, leaking through like a dripping faucet.
i replaced the inlet valve because it was not making ice and freezing at the fill tube but before i replaced it i had to use hairdryer to thaw out the filltube
