Ice not dispensing
Brand: GE
Model Number: pye22kelnds
Main Symptom: ice not dispensing
Error Code (if any): none
Parts or tests already tried: replaced main board and ice dispensing assembly.
You will want to test to make sure that the auger motor is getting 120 vac to it. If it is but will not run then the auger motor will be the issue.
The auger motor is getting erratic voltages. I’ve tested another similar unit( different model number but same parts), and auger motor works with 158 vdc !! It could be the small board on top of left door where the relays are? What part that one is?
