ice maker
I just replaced the solonid system and the icemaker assembly (AP3182733 (2198597) Complete icemaker assembly (8 cube) on my whirlpool gold (mod.gd5rhaxnqoo) refridgerator. I cannot get it to dump water to the tray or cycle . I jumpered the wires on the water dispenser to the icemaker fill and confirmed that it works.
The bin overfill appears to work correctly . I also unplugged the box for 20 seconds in case something needs reset/ I am now at a loss on what to do next
Hello.
Please, explain what parts beside the ice maker have you replaced.
How did you tested the optic bin control and water fill?
I would appreciate a bit more info.
Please reply. Thank you.
both solonids and icemaker are brand new. I tested the water to the icmaker using the wire from the door water. I unhooked wires from icemaker and held the wires from the door water against the icemaker solonid and pressed the water switch which in this case activated the solonid to the icemaker.
Hello.
Most likely the problem is bad bin control, you replaced all other parts involved in the proses.
The bin control AP5956767
Read the instructions enclosed.
It’s easy to replace, don’t forget to unplug the refrigerator.
Post the results.
Thank you.
