this fridge has an in door ice and water dispenser. The Water works but the ice maker has stopped making ice. The lines seem to be okay.
Check to make sure the fill tube isn’t frozen and the bail arm is down if so then, Switch the leads on the water valve and press the dispenser and see if you get water in the ice maker.
Post your results.
nat
