Hi there! If your Maytag refrigerator, model MSC21C6MFZ00, is only making one batch of ice every 24 hours, something is definitely slowing down the ice-making process.
Since you’re getting good water pressure at the dispenser, I wouldn’t replace the water inlet valve just yet. The dispenser and ice maker use different water paths, so good dispenser pressure doesn’t completely rule out a water supply issue.
I’d start with a few simple checks before replacing any parts.
1. Check the freezer temperature first
This is the most important test.
- The freezer should ideally be around 0°F.
- If it’s running above 10°F, ice production can slow down considerably.
- Place a thermometer inside the freezer and check the actual temperature rather than relying on the display.
Even if everything feels frozen, the freezer could still be too warm for normal ice production.
2. Check the ice maker’s water fill
Look at the ice mold after it completes a harvest.
- Full-sized cubes: The water supply is probably adequate.
- Small or hollow cubes: Check the ice maker fill tube for a partial ice blockage and consider a restricted water supply or inlet valve.
- Mold full of frozen ice but not harvesting: The problem is more likely with the ice maker’s cycling mechanism, temperature sensing, or electrical supply.
3. Check the ice maker shutoff and ice bin
Remove the ice bin and check that the ice maker is switched on, the ejector mechanism isn’t jammed, and the ice-level sensing mechanism isn’t obstructed.
This model also has a Fast Ice feature that you can activate through the OPTIONS button. It can help increase production, but it won’t correct a failed component.
ManualsFile
+1
4. Determine whether the ice maker needs replacing
If the freezer is holding around 0°F, the mold fills with normal-sized cubes, and the ice maker simply waits many hours before harvesting, I would suspect the ice maker assembly or its temperature-sensing system.
I would check those before considering the refrigerator’s main control board.
A couple of questions
- When it finally makes ice, are the cubes normal-sized and completely frozen?
- Do you know the actual freezer temperature?
Those two answers will help narrow this down considerably. If the cubes are normal and the freezer is at 0°F, we can focus on why the ice maker isn’t cycling rather than spending money on a water valve you may not need.
