Hi all…The water line that feeds my ice/water dispenser has developed a pinhole leak. Can I buy the parts to repair the pinhole leak or is it possible to buy a whole new water line kit and replace the whole thing? The water line came with the refrigerator and is that flexible white plastic material that is about 1/4 in diameter. Thank you for any help you might offer me!!
If the water line is exposed, and its just a small leak, try cutting the line on either side of the hole and then use a John Guest or compression water fitting to tie to two ends back together.
