I have a Kenmore Refrigerator and it stopped making ice. I have got through every troubleshooting step that I can find online. Here is where I am at.
Replaced water valve
Replaced Ice Maker.
- I can Jump t and h on the ice maker and it will cycle
- At the end of the cycle I see 120 v on the “V” for a second.
- If I jump V and L the valve does not open an deliver water.
- If I apply 120 volts directly to the valve it does open and deliver water.
- When I jump V and L on the ice maker the plug going to the valve still reads 0 volts.
To me it seems that there is a break somewhere between the Ice Maker and the plug on the valve. How can I find this? Is there an easy way to get to the wiring? The part of the wire (brown) that I can see looks fine.
I have been struggling with this for a while. Any help you can provide would be much appreciated.
thanks
