Brand:Maytag
Model Number:mzd2766ges
Main Symptom:how to attach ice maker to brackets
What happens & when:there are brackets instead of the screws in the video
For Maytag MZD2766GES, the brackets you’re seeing are normal. This side-by-side uses snap-in mounting clips for the upper part of the ice maker, rather than the two upper screws shown in many generic videos. Maytag’s installation instructions describe sliding the ice maker’s tabs under the clips and pushing upward until they snap into place.
Unplug the refrigerator first. Connect the ice-maker wire harness, then make sure the water fill tube enters the ice maker’s fill cup. Line up the two upper mounting tabs on the ice maker directly below the freezer-wall clips. Push the ice maker straight up and slightly toward the wall until both tabs snap into the clips. You may need fairly firm pressure. Then secure the lower/front mounting bracket with its single screw.
A repair account specifically for the MZD2766GES confirms the same arrangement: two snap-in attachment points along the upper side plus a single lower/front screw and bracket.
If you send me a photo of the brackets and the side of your new ice maker, I can point out exactly which tabs go into which clips.
Yes. I did as you suggested and it worked. I was hesitant to push too hard because they cost $43 dollars each, but it went well. Thank you.
