Ice maker stopped working
Brand:kitchenaid
Model Number:KUIX535HPA
Main Symptom:NO POWER
What happens & when:Stopped working
This model probably has the external drain pump module AP7034245 in the back in the machine compartment.
Easy check, follow the power cord from the wall to the ice maker. If it has the drain pump module you’ll see the power cord running to it, there should be another power cord plugged into that pump that goes into the ice maker. If this is what you’ve got, disconnect the ice maker from the outlet, unplug the power cord going from the drain pump into the ice maker, and plug it directly into the outlet at the wall. If the ice maker powers on and seems to be working then that external drain pump module will need to be replaced.
https://www.appliancepartspros.com/whirlpool-drain-pump-assy-w11539855-ap7034245.html
