Ice maker stopped working- water dispenser IS working
Brand:Frigidaire
Model Number:GRMC2273CD03
Main Symptom:Ice maker stopped working
What happens & when: Fridge is 15 months old. Originally ice maker worked fine, noticed water leaking from water dispenser area and after looking further, water was coming from ice maker. Turned everything off except water until i could have repaired. 3 months later i replaced inlet water valve, ice maker and new inlet water filter and turned ice maker back on. Nothing is working or seem to be getting water to ice maker itself ?
Still getting water at the dispenser? And did you purge water through the system after replacing everything?
If that’s working and the system has been purged, make sure the water lines between the icemaker and the valve are clear and haven’t frozen up. Should be able to disconnect the lines and blow through them.
If those are clear I’d use the tech sheet I’m attaching below to run tests 50 and 78 to see what they tell you.
Frigidaire GRMC2273CF00 Refrigerator Service Data Sheet A23689302.pdf (435.7 KB)
Water supply to the fridge main valve has only one supply line leaving into the top of the fridge. Water is making it to the dispensor. Somewhere in between there it isn’t making it to the ice maker. When i feel the top of the ice maker area as to where the water fills the tray, it is slightly warm so i don’t believe it is freezing up. Is there a schematic showing more detail of the the water line route? Is there another valve inbetween the dispensor and ice maker? if so how do i get to it, seems impossible.
