Ice maker Samsung won't continue to make ice
Brand: Samsung
**Model Number:**RF28HMEDBSR/AA Rev 14
Main Symptom: The Ice maker doesn’t continue making ice.
What happens & when: The ice maker stopped making Ice. I replaced the ice maker Assembly Nov 21, 2025. I can hold the blue test button it will cycle and spit the ice out and fill the ice maker back up but won’t continue to make ice. If I wait and go back and hit the blue test button it will cycle again spit the ice out refill but never continuously makes ice.
Error Code (if any): None
Parts or tests already tried: Replace Ice Maker Assembly Part #PD00037355 | Mfg #DA97-15217D. I ran a defrost on the refrigerator and cycled power on the refrigerator waiting 5 minutes between power up.
It would be recommended to check and make sure that there is 120 vac coming off the control board to the heater on the icemaker. Also check to make sure that the resistance reading for the icemaker is good. These would be the 2 most common causes for this to occur.
