Ice maker only works when reset
Brand:Samsung
Model Number:RF263BEAESR/AA
Main Symptom:only makes 1 batch when reset button is pushed
What happens & when:push reset button, makes one batch of ice Need new red laser light to show ice cube tray is not empty
The emitter for the ice maker section is a part of the auger assembly. An easy check to identify if it has failed would be be to use the selfie camera of a phone to take a picture of the sensor. A camera with no filter can usually pick up the IR light, and a selfie camera usually does not have an IR cutting filter. If it looks like it is illuminated, the sensor is operating. Here is a link to the auger motor assembly just in case. DA97-12540G Refrigerator Ice Maker Auger Motor | Genuine Samsung OEM In Stock
