For your GE Profile PFCS1NFZCSS, since the icemaker does fill with water but then does nothing, I would move away from the inlet valve. The fact that it fills tells us the icemaker can call for water and the valve can respond.
Start with the freezer temperature
Check the actual temperature with a thermometer placed near the icemaker. GE specifies approximately 0°F as the recommended freezer temperature, and the icemaker needs to get down to roughly 16°F or colder before it will initiate an ice-making cycle.
If the freezer is running 15–20°F or warmer, troubleshoot the cooling problem first.
Quickest icemaker test
If there is currently water frozen into cubes in the icemaker mold:
- Make sure the icemaker is ON.
- Make sure the feeler/shutoff arm isn’t blocked.
- Give it enough time for the water to freeze completely.
- Watch whether the ejector fingers ever begin moving.
If the water freezes solid but the cubes remain in the mold and the ejector never moves, you’ve basically eliminated the water valve and fill system.
That points strongly toward the icemaker assembly itself—particularly its internal thermostat/control, mold heater, or harvest motor.
Forced-cycle test
This style of GE electronic icemaker has a useful diagnostic. The service diagnostic forces a harvest followed by a water fill, regardless of icemaker temperature or feeler-arm position.
With the icemaker powered:
- Move the feeler arm from the out position to the in position and back out.
- Do this 3 times within 15 seconds.
- The icemaker should begin a harvest cycle.
- The ejector should rotate through a complete cycle.
- Near the end, it should energize the water valve and refill.
If it fills normally during testing but will not move the ejector/harvest the frozen cubes, I would replace the icemaker assembly rather than the inlet valve.
One additional confirmation
You can also do GE’s simple water test in reverse: if the mold is empty, manually add about 4 ounces of water and give it approximately 2–3 hours. GE recommends this test specifically to determine whether the icemaker can freeze and eject a batch.
In your case, because it’s already filling itself, I’d concentrate on this:
Water fills → water freezes solid → no ejector movement = icemaker/harvest failure.
If the cubes aren’t freezing solid, then we need to diagnose freezer temperature/cooling instead.
