Brand: Whirlpool Model Number: WRX735SDBM02 Main Symptom: Not Filling with water What happens & when: Unit quit making ice. Fill area was frozen over. Removed and thawed it out. After I re-installed I don’t hear it coming on to fill with water. I have removed and thawed multiple times. Never had this issue
Try this, pour a little water directly into the icemaker and see if it freezes and ejects the ice. If it does, the icemaker is good, if not, the fill tube may be frozen up and not letting water into the icemaker. When it goes into a harvest mode, at some point you can hear a slight hum, that is the inlet valve being energized. If it does not hum, the inlet valve may need to be replaced.
