imodel number lsd2615heb I changed the water valve in the back ok the frig. There is water at the door but not the ice maker,I also blew out all the water lines The ice maker fingers are working (they go around)s there something else that calls for water to the ice maker
Tarezzi,
The only other components involved would be a bad fill circuit in the ice maker itself,
Or a loose or broken wire from the ice maker connection, back to the fill valve.
Do you have a multi meter so you can check for 120 VAC at the ice maker solenoid (tan and white wires) when the icemaker cycles ?
It will be one or the other, based on your post, and what repairs you’ve already made.
Hello,
More than likely the ice maker has failed, there is a fuse that is on the side of the ice maker check it for continuity.
Here is a link it has two different videos that explain how to test and diagnose your refrigerators ice maker and water valve.
