Thanks for the additional information. Since you’ve already checked the ice maker ON/OFF switch and ice bin switch, and none of the three ice makers has attempted to operate, I would concentrate on the freezer-door wiring harness and the electrical supply to the ice maker.
Your Whirlpool WRS588FIHZ04 has an ice maker mounted in the freezer door. The power and control wiring passes through the door hinge area, making that an important place to inspect.
1. Where to find the wiring diagram
Whirlpool commonly places the technical information sheet behind the lower front grille, beneath the refrigerator, or in a service-document pouch elsewhere on the cabinet.
The wiring diagram should help identify the ice maker’s power connections, door switches, and control-board connections.
2. Where is the ice maker power supply?
The ice maker receives electrical power through the refrigerator’s wiring and control system. There isn’t necessarily a separate power supply box dedicated to the ice maker.
The important question is whether the correct voltage is reaching the ice maker connector.
Don’t apply 120 volts directly to the ice maker or jumper terminals until we’ve verified the correct wiring and voltage specifications.
3. How to run the ice maker harvest diagnostic
I was able to identify the correct technical sheet for your refrigerator: Whirlpool W11575236. Your NTPV303WA1 marking also cross-references to ice maker assembly W10873791.
All-Brand Model Lookup+1
You can find the model’s documentation here:
Whirlpool WRS588FIHZ04 – Owner Support
The closely related Whirlpool diagnostic procedure uses these tests:
- Test 44 – Ice Maker Harvest: Commands the ice maker to cycle.
- Test 45 – Ice Maker Fill: Checks water filling.
- Test 47 – Ice Maker Switch: Checks ice maker switch operation.
- Test 48 – Ice Bin Switch: Checks ice bin detection.
For Test 44, the related Whirlpool tech sheet says to install the ice bin, make sure it isn’t full, and press SW3 to initiate harvesting. The display then reports whether harvesting is running and whether the bin is detected as full.
Rev A
However, I haven’t verified that the exact button sequence and test numbers are identical on your WRS588FIHZ04. I would use your W11575236 sheet to confirm the procedure before starting.
4. Check the door hinge wiring
With the refrigerator unplugged:
- Remove the lower front grille.
- Locate the wiring connections underneath the freezer door.
- Inspect the wires where they bend near the lower hinge.
- Look for broken wires, cracked insulation, corrosion, or loose connectors.
- If nothing is visible, a continuity test may be needed to find an internal wire break.
Whirlpool’s door-removal instructions confirm that the freezer-door electrical connectors are accessible behind the lower grille.
ManualsFile
What I’d like you to do next
Start with the wiring inspection and the harvest diagnostic.
Please let me know two things:
- Did you find any broken or damaged wires near the freezer-door hinge?
- When you run the harvest diagnostic, does the ice maker attempt to move, and what numbers appear on the display?
Those results should help us determine whether we’re dealing with a damaged door harness, missing electrical supply, or control problem.
I would hold off on replacing any more parts until we have those results.
tech-sheet-w11575236 (1).pdf (605.1 KB)
