Ice maker not working - Kenmore Elite
Brand: LG Kenmore Elite
Model Number: 795.74305.810
Main Symptom: No power to ice maker
What happens & when: No power to ice maker
Hello - our ice maker stopped working.
We replaced the ice maker (twice) with LG AEQ73130004 Genuine OEM Ice Maker Assembly for LG refrigerator. Still no power after assessment by Mr. Appliance tech. After two ice makers, we think we can rule out the ice maker itself.
Moved on to replace LG ABQ72940031 Refrigerator PCB Case Assembly as below. No change, ice maker still unresponsive.
Does anyone have suggestions on next steps for troubleshooting? The fridge/freezer is working normally. Freezer temp is at 0 degrees and holding. Fan to the ice maker compartment is also working and temperature in the ice compartment is also holding. Pressing the test button on the ice maker, nothing happens, no movement or response from the ice maker.
Appreciate any additional thoughts - thanks!
Hello! Thanks for the detailed information and photos.
Since you’ve already replaced the ice maker twice and the PCB case assembly (ABQ72940031), I agree that it’s time to stop replacing parts and concentrate on finding out why the ice maker isn’t receiving power or responding to the test button.
On your Kenmore 795.74305.810, which uses LG components, I’d focus on three areas:
  1. Ice maker wiring harness: Check for damaged or broken wires, loose connectors, or corrosion between the ice maker and its power source.
  2. Door switches and ice maker compartment switches: A switch or its wiring may be preventing operation, depending on how this model controls the ice maker.
  3. Main refrigerator control board: Even though the refrigerator is cooling normally, there could still be a problem with the circuit supplying the ice maker.
The fact that your freezer is holding 0°F and the ice compartment fan is working is encouraging. It suggests the cooling system is functioning, so we can concentrate on the electrical side.
Here’s what I’d check next
Step 1 — Verify power at the ice maker connector.
Have the technician check the ice maker’s supply voltage and ground directly at its connector using a multimeter.
The AEQ73130004 is compatible with your model, but we need the correct wiring diagram before identifying specific pins or expected voltages.
eReplacement Parts
Step 2 — Inspect the wiring through the refrigerator door.
This is where I’d concentrate next.
  • Unplug the refrigerator.
  • Inspect the wiring near the upper door hinge and where it enters the ice maker compartment.
  • Look for pinched, broken, or corroded wires.
  • Check continuity from the ice maker connector back toward the control board.
A wire can break internally while the insulation still looks perfectly normal.
Step 3 — Check the main control board output.
If the ice maker isn’t receiving the proper voltage, the technician should check whether that voltage is leaving the main control board.
  • Voltage at the board but not at the ice maker: Suspect damaged wiring or a connector.
  • No proper output at the board: Investigate the board, its inputs, and any ice maker enable conditions.
  • Correct voltage and ground at the ice maker: Recheck the test procedure and control signals before replacing anything else.
A couple of questions
  1. When the Mr. Appliance technician said there was no power, did they actually measure voltage at the ice maker connector? If so, what reading did they get?
  2. Does the ice maker have a power switch, and is it turned ON?
  3. Is the ice maker located in the refrigerator door, as shown in your first photo?
With those answers, we can narrow this down considerably. At this point, I’d suspect a wiring or control-board supply issue before purchasing another ice maker or PCB case assembly
Hey Jeffrey - thanks for the quick and thorough reply! The Mr Appliance tech said there was power to the unit, although not sure if he actually tested properly. Mentioned a bunch of numbers at various points around 60ish at each point and then he did “math” to add two together and said that’s over 120 so we’re good. I’m not an electrician but the reasoning sounded suspect.
No power switch on the ice maker itself. and the ice maker is in the refrigerator door.
I don’t have confidence that original tech can troubleshoot effectively any further. Probably need to engage with a new tech, but not sure how to get the right guy with the right experience that can actually troubleshoot and resolve properly.
