Ice Maker not working again
Brand: Maytag
Model Number: MFX2571XEM3
Main Symptom: Ice maker line frozen at fill cup
Error Code (if any): None
Parts or tests already tried: Shunt wire tried, no motor movement. Replaced this ice maker along with water supply valve March 2025.
Photos / video link: None
This is the third ice maker in 2 years. Was working fine until 4 days ago when it froze up.The water dispenser line works fine. Have unplugged, check the back for crimps, no electrical outage lately. Any other suggestions? Is the last ice maker still under warranty (order no. AP6019087)?
I’d start with checking for 120v AC at the violet and whites wires on the harness connected to the ice maker with the door switches taped down. That many ice makers in such a short period usually indicates something else in the system being messed up. Was the harness to the ice maker ever replaced?
As for warranty questions, the # you have provided is the part # of the ice maker, not the order #. Please contact us at 1-877-477-7278 for any warranty questions you may have.
