Ice Maker Not making Ice
Brand:GE
Model Number:gss25gshjcss
Main Symptom:Ice Maker not making Ice
What happens & when:Makes ice for a day or two then gets stuck and wont eject ice
Parts or tests already tried:Installed new ice maker
With a new ice maker installed it sounds like a water valve or maybe a water pressure issue. Check to ensure the valve is not leaking through or that it is not adding too much water when it cycles.
