Brand: Kenmore
Model Number: 253.7042341B
Main Symptom: Ice maker quit working
What happens & when: Ice maker just doesn’t make ice
Error Code (if any): No error codes
Parts or tests already tried: I’ve replaced the water valve and the actual ice maker itself
Photos / video link: N/A
I’ve tried replacing the two parts that I assumed were the issue, the water valve first and then the ice maker itself and still no ice. The water valve in the basement is turned on so there is water going to the fridge. I have turned off the fridge several times and let it sit for 10 minutes or so to try and reset it hoping that would work but still no ice? I thought maybe there was a reset button on the ice maker itself but that doesn’t seem to be the case. Looking for possible suggestions? Thanks.
