[SIZE=3][COLOR=#000000][FONT=Calibri]The ice maker is no longer producing ice. I can get the water to the fountain in the door, but nothing to ice maker. I changed the water valve thinking that I was not getting water to the ice maker from there, this did nothing for me. Would anyone have any ideas on a troubleshooting process to try to isolate the problem? [/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]Mike [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]If you remove the front cover off the icemaker you will see test points. This page will explain in detail how to use them. I know it says whirlpool icemaker but you have that type icemaker on your refrigerator. Whirlpool Icemaker Repair Guide[/COLOR][/SIZE][/FONT]
It appears as though the motor module is bad. I was able to get water via the “V” to “L” jump, but there was no cycle with the “T” to “N” jump.
What do I need to replace to get this to work?
Thank you for your help on this. Maybe I can get by without indiscriminately replacing the entire refrigerator!
Mike
[FONT=Times New Roman][SIZE=3][COLOR=#000000]The motor module part number 628366. Note that the whole ice is does not cost much more than this part. Whole icemaker part number 1129313. [/COLOR][/SIZE][/FONT]
