Ice maker in GYE18JSLGFSS GE refrigerator not working
Brand:GE
Model Number:GYE18JSLGFSS
Main Symptom:no ice
What happens & when: replaced icemaker, still no ice
You will want to check to make sure that the fill tube is not frozen. If it is not then you will want to cycle the icemaker and test to make sure that there is 120 vac to the dual valve. If there is 120 Vac then the valve is faulty and would need to be replaced.
