Ice Maker Flow Tube
How do I replace the ice maker Flow Tube? I think it is jammed up and I want to remove it from the fridg. Do I pull it out of the back or what? Can you help?
Is it the fill tube that the water comes out of to fill the ice mold you want to take out. It comes out from behind the icemaker. Most you can just hold it twisting and pull it out.
Or is it the water line on the back of the refrigerator you want to take out.
Hi, Yes, it is the fill tube coming out of the back. I’ll try and twist it some more. I tried to pull it out but didn’t have any luck. I was afraid I might break something. I found the part online to order. Thanks.
