Ice maker filter will not come out
Brand: FRIGIDAIRE
Model Number:GRFS2853AF2
Main Symptom:ICE MAKER FILTER WILL NOT COME OUT
What happens & when: I TRIED TO CHANGE ICE MAKER FILTER BUT IT WILL NOT COME OUT. IT WILL WIGGLE SOMEWHAT BUT THAT IS ALL. IT STOPPED MAKING ICE.
I’m assuming that you mean the water filter AP7180368 when referring to the ice maker filter. If that filter isn’t coming out it could be stuck in the filter head AP8064646 or the filter has swelled and is stuck in the filter housing AP7180368. Either way, you’ll need to take the lowest drawer/tray out and probably that frame above it to access the left-hand drawer support that the filter components are housed in and remove it to figure out what is going on.
https://www.appliancepartspros.com/frigidaire-manifold-water-filter-140156010054-ap8064646.html
https://www.appliancepartspros.com/frigidaire-housing-5304530987-ap7180368.html
