Ice Maker Dispenses Crushed Ice But Not Ice Cubes
My Mother’s GE Refrigerator is dispensing crushed ice but is reluctant to dispense ice cubes. The Ice Maker is making ice cubes at a good rate; however, it does not want to dispense ice cubes. Any suggestions to get started to troubleshoot this issue? Thanks. Joe.
Hi Joe,
The first thing I would check is 120VAC coming to the solenoid (#378 on the break down diagram) while the ice dispenser calls for whole cubes. Also check the solenoid itself for continuity.
I have the same problem with my whirlpool refrigerator. I checked the continuity of yhe solenoid with a digital ohmmeter and got a reading of 35 so I assume the solenoid is OK. Any other suggestions?
Rich,
What is the complete model number of the refrigerator?
Check for 120VAC coming to the solenoid with the light switch depressed while the ice dispenser calls for the ice cubes.
[QUOTE=Gene;34397]Rich,
Gene.[/QUOTE]
the model no. is ET22DQLDN01. How do you check for the AC working on the solenoid?
You have to have a simple multimeter with ability to measure voltage and resistance.
Here are the break down diagrams for the Whirlpool refrigerator Model ET22DQLDN01
My suggestion is that if you don’t care about crushed ice just remove the bar that goes along the ice tray and into the solenoid. You will then get cubes 100% of the time. Wala! That’s all I wanted anyway. :slight_smile:
I have a GE profile with the same problem that you are having. You can remove the ice maker engage the door closed switch and put the switch on the front panel in the crusted ice position, push the switch to get ice and if the solenoid energies and the motor tries to turn the problem is probably is the logic board in the door. The other thing that can cause the problem is a clump of ice in the ice bin.(per GE web site) Swapped the logic board, fixed!
I just purchased a used GE Profile Artica side by side. Everything’s working great except it is only dispensing cubed ice. I followed the recommendation in this thread (open door, engage door closed switch, toggle between cubed and crushed). Sure enough, the solenoid isn’t doing anything so it’s not moving the bar in the tray to open the cubed ice slot.
Any recommendation on what to do? Is it possible that one of the wires in the connection at the bottom of the freezer is loose (I had to disconnect the electrical at the bottom of the freezer and the icemaker line to get the door off to get it inside the house). If this isn’t a possibility, what else could be causing it not to raise the bar in the tray?
Is this a DIY situation? if fixing it would cost more than $150 (call, repair, and parts) then I’ll probably just keep a separate ice bin below it and access ice from it (keeping it refilled from the main bin). I don’t mind opening the door to get ice if it saves me a lot of $$$.
Someone mentioned taking the bar out in the tray - I don’t care about crushed ice, and would be willing to forego crushed ice to gets cubes through the door. I can’t seem to figure out how to get that back out of the tray? Wouldn’t you still need the bar to pull the ice cubes forward?
Thank you for any help!
You may want to check the solenoid for continuity.
Gene, thank you very much for your reply.
How would I check the solenoid for continuity? Is this something I can do on my own?
The refrigerator is a GE Profile Artica Side by Side, model number PSS26LSRD SS.
Thank you!
This test is very simple. You’ll need a simple multimeter which you can buy at any hardware store or Radio shack store. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter.
In order to access the solenoid (#378 on the diagram) you have to remove the ice maker, the ice bin and the motor & solenoid cover.
Here are the breakdown diagrams and Replacement parts for General Electric PSS26LSRDSS Refrigerator | AppliancePartsPros.com
i saw the post about removing the bar but on mine appears to lift the bar to open it for non-crushed… am i wrong? thx!
