Will the New model of Whirlpool icemaker(4317943) work in place old Whirlpool icemaker(106 626440) for the above Admiral side-by-side refrig?
yes can be used
[quote=AIMANNY;134546]yes can be used[/quote] I replace it last night and it will fill but that is it. Any suggestions?
did you replace th metel bar.
[quote=AIMANNY;134559]did you replace th metel bar.[/quote] What {th meter bar} are you referring to? I followed the instruction and verified the 4 wire wiring harness to make sure all was correct. I use one of the new metal shutoff arms. It did fill up but would never dump. (I quess the heater would never kick on and the fingers stoped at the 4 o’clock postion) Customer service requested that I check with you guys before they replace the unit. I thought these unit were a plug and play items with no adjustments except to verify that it was level.
it stoped at 4 oclock. your ice maker is bad.
