Ice maker arm
This might seem like a very basic question but I have never had one apart before.
This is a Whirpool style module. I have a replacement module on the way here. I have to transfer the cable (easy) and the on-off arm.
The back end of the old arm is easy to remove, but I am having trouble with the front end where it goes into the controller. How is it attached? Is it just a push fit or is there a hook or other feature to hold it in place?
I don’t want to break or bend anything by being heavy handed in trying to disengage it. It just might be stuck or it might be secured somehow. How do I get it out. If I had a new one coming I could see what that hidden end looks like.
Thanks Charlie
Charlie
They use so many different ones can you post your model number and the IM part number.
Nat
[QUOTE=libertyappl;35870]Charlie
Nat[/QUOTE]
The fridge is an Amana bx22tw
The label on the ice maker has IM #S 10S 626639
Hope these help
Charlie,
It looks like it just slides in.
Here is the breakdown on your unit. Model BX22TW
Nat
