Ice dispenser does does not let ice come out
Brand: Frigidaire
Model Number: FSC23F7HW6
Main Symptom: No ice from ice dispenser on the outside of the fridge
What happens & when: When pressing the dispenser lever.
The first place to start for this will be to check the switch and paddle for the ice dispenser. One of these may be faulty causing the unit to not dispense ice. If they are good then test to make sure that the auger motor is getting 120 vac to it and if it is but not turning then replace the auger motor. Also, check the coupler on the motor to make sure that it is not stripped.
