What happens when you push the ice release lever?
Does it make any noise?
no it does not make any noise, there is no movement of the auger all that works is the ice maker, that produces ice with no problem.
Remove the dispenser front panel and check the micro switch and the bracket (#14 & #15 on the diagram). The disassembly instructions are attached to the reply.
Here are the breakdown diagrams and Dispenser front replacement parts for WHIRLPOOL GD5LHGXLQ01 | AppliancePartsPros.com
Ice and water dispenser.pdf (406.6 KB)
