Ice block
Evening all,
The ice maker on my sub-zero over/under seems to make ice fine, but when it drops into the hopper, it seems to eventually becomes a block of ice. I suspect there might be an overfill of water and this spills into hopper and freezes. Any ideas for a quick fix or where the best place is to get parts. Thanks
[quote=jaygee;316991]Evening all,
The ice maker on my sub-zero over/under seems to make ice fine, but when it drops into the hopper, it seems to eventually becomes a block of ice. I suspect there might be an overfill of water and this spills into hopper and freezes. Any ideas for a quick fix or where the best place is to get parts. Thanks[/quote]
Jaygee,
You most likely have a “seaping” fill valve, and will most likely need to replace it.
Unfortunately, AppliancePartsPros.com has no access to your model number or brand machine,
Your best bet for parts is the manufacturer, or an authorized factory parts and service company, with access to Sub Zero parts.
Good Luck,
